Fuel Moto header flange to jug gap?
Old 04-11-2013, 10:21 AM
EastSideBikerTrash's Avatar
EastSideBikerTrash
EastSideBikerTrash is offline
I had the same concerns and called FM and talked to Jamie. He said to use the stock gaskets and suggested there should be no need to replace or remove them. The FM header should fit flush against the stock gaskets. The exhaust nuts should be tighten so that the end of the stud is flush with the nut. No stud protruding past the nut according to Jamie to prevent over tightening which will crush the gasket.
Old 04-11-2013, 11:21 AM
SSTuner's Avatar
SSTuner
SSTuner is offline
Also make sure the FM flange is actually in the bore and not hung up on the aluminum outside flange. Tighten evenly.
Old 04-11-2013, 12:00 PM
Dozer40's Avatar
Dozer40
Dozer40 is offline
My FM pipes came with Cometic gaskets and headpipes installed easily.
Zoogie
2014-2023 Touring Models
24
03-14-2015 09:20 PM
barrygreen
11-14-2014 06:33 PM
harleyflo
05-05-2014 05:52 AM
btmonnat
09-18-2012 09:20 AM
zenwarrior
Exhaust System Topics
05-20-2007 10:50 AM
Quick Reply: Fuel Moto header flange to jug gap?
