too late at 20k???
Old 04-10-2013, 05:12 PM
Alias69's Avatar
Alias69
Alias69 is offline
Default too late at 20k???
been running reg hd 20-50 and so has the previous owner for the past 20k miles on my 09 rk...been looking to switch to mobil 1 vtwin 20-50 for my eng, redline oil for my primary and tranny... is it too late to switch?
primary currently takes hd+ primary oil and tranny uses the belray stuff that hd sells
Old 04-10-2013, 05:14 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,605 Likes on 2,725 Posts
Too late for what? Its fine.
Old 04-10-2013, 05:33 PM
Snowmaster113's Avatar
Snowmaster113
Snowmaster113 is offline
Never to late to switch oil. I switched oil brands on my bike when it had 45k on it
Old 04-10-2013, 06:25 PM
Juice's Avatar
Juice
Juice is offline
I was always told even on cars to not let the 1st oil change when switching go the distance. Run it a thousand and change oil and filter then the normal interval.
Old 04-10-2013, 06:51 PM
nsp261's Avatar
nsp261
nsp261 is offline
Why?????
Old 04-10-2013, 06:57 PM
Juice's Avatar
Juice
Juice is offline
Was told that the synthetic and dyno oil would gel/gum up.
Old 04-10-2013, 07:01 PM
Proud Marine Dad's Avatar
Proud Marine Dad
Proud Marine Dad is offline
I switched to synthetic at 30,000. Should have done it sooner. Bike ran cooler and quieter. Switched to Synthetic in the primary ay the same time.
Old 04-10-2013, 07:10 PM
06Cummins's Avatar
06Cummins
06Cummins is offline
Haha!!! That's some funny stuff it will not gel and you can switch oils out as many times as you like. I did it ony wife's Durango many times when I didn't have the money to keep full syn in it so every other oil change I ran full syn. With Lucas oil additives. So you will be fine.
Old 04-10-2013, 07:11 PM
davey019's Avatar
davey019
davey019 is offline
You should just be fine. But I wouldn't keep switching back and forth
ynots's Avatar
ynots
ynots is offline
If you want to start using synthetic go for it
You've been missinformed. Note: Not all synthetics are a full synthetic. They do also make blends
Quick Reply: too late at 20k???
