Muffler replacement
Old 02-17-2007 | 12:01 PM
danbo's Avatar
danbo
Default Muffler replacement
Looking to change the mufflers on a new road king. I don't want loud, just a bit more sound than the stockers with better flow than the stock ones. I'll be adding a stage 1 A/F too.[/align][/align]I know there must be some out there that wanted the same thing.[/align]What mufflers did you get ? Much louder? [/align][/align]All input appreciated.[/align]
Old 02-17-2007 | 12:39 PM
sportyrider1's Avatar
sportyrider1
Default RE: Muffler replacement
probably what you are looking for is either the HD SE performance touring muffler or something from the supertrapp/kerker se series. don't forget if you are changing the AC and the mufflers you are going to have to do something about the fuel management. sert or pcIII you will get different opinions about which one, either will do the job fine on a stage 1 bike.
in mho because I have been there I would spend the extra ( not that much ) for a supertrapp supermeg 2-1 instead of the slipons. heat problems go away, lots more usable power and no louder than the se's at highway speeds.don't worry about the look, you get over that really quick like the first time you head down the street.
Old 02-17-2007 | 02:05 PM
ext1bab's Avatar
ext1bab
I just put on the Supertrapp SE slip-on's with a SERT and SE Air cleaner. I'm told it will provide a little deeper sound then stock, but improve performance by 10 to 15%. I can't vouch for it yet because too much ice and snow to ride.
Old 02-17-2007 | 03:31 PM
HarleyArcher's Avatar
HarleyArcher
Default RUSH
Check out Rush! I just ordered a set and you can get different size baffels for different volume levels. Google them and listen to their sound clips. $280 a set is a great price also!! Bryan
Old 02-17-2007 | 03:39 PM
dougbk's Avatar
dougbk
I have to second the Rush mufflers.
Old 02-17-2007 | 04:31 PM
UltraKla$$ic's Avatar
UltraKla$$ic
[sm=ummmmokay.gif]Whaaaaaaa?
You makin me dizzy![&:]
Old 02-17-2007 | 06:57 PM
Dogwood's Avatar
Dogwood
Default RE: RUSH
Those Rush look good.
Here's the link, it was hard to find, for me at least.
http://www.epiflex.com/rush_touring.html
I can hardly tell the difference between the sounds, which baffle did you get?
Mr. Clean
10-16-2007 12:03 PM
pauly_2
Exhaust System Topics
09-22-2007 08:09 PM
Road Glider
08-02-2007 11:46 AM
danbo
02-24-2007 07:34 PM
peppi
02-19-2007 08:56 PM
Quick Reply: Muffler replacement
