I got to looking today. There is a set of holes about 1/4 inch under the stock passenger foot pegs. My wife is complaining about leg position, so I was wondering if I could lower them to the unused hole?
13 street glide. I have true duals, rc components. It looks like the bracket will clear. I am not very mechanical (Other than oil changes), so I thought I would ask before I did it.
I added a set of the adj floor boards on my FLHX. Have a few inches of adj. got them set perfect for the wife
On the new frame you take out the top bolt, bottom bolt is a shoulder bolt so the bracket will slide on that bolt, you have 2 holes below the top bolt hole you can set the bolt in either of the 2 lower holes. I have done this to a few bikes for longer legged passengers, it only moves about 2 inches to the bottom hole but makes a big difference. Hope this helps.
The very bottom bolt hole has a rubber plug, you can remove the plug and lower the peg/floorboard mount. The bolt hole is a smaller bolt/screw, it comes with the floorboard kit for the street glide. I can check to see what size it is if you want.
