power vision datalog/auto tune time on road?
Load the tune Jamie sent you. Go into autotune and select that tune. Do an autotune run. Then export the results into a slot different from the one Jamie sent you (empty slot if you have one). Then go to load tune and select custom tune and select the autotune that you just saved. Answer yes when it asks if you want to reset values......... turn bike off for 10 seconds.... you're done.
http://youtu.be/l1fppB5rSYo
I could not get the tune to open on my lap top this morning when I was at the house. Jamie just emailed me and said I need to save the attachment first then open it on the WinPv software that I have downloaded from the disc. I will also follow your directions and do that as well.
Jamie's right.... you need to use the WinPV software to get the tune into the Power Vision.
I'm not very computer savy so when the screen came up thet said save it under blah blah I ex'd out of it. Last time I "saved" something the misses found it and she wasn't too happy about it. But once she watched the "video" a couple of times it made for a very enjoyable evening. LOL
