Installing the Hayden M6 tensioner
Old 04-04-2013 | 10:46 AM
TUCCI's Avatar
TUCCI
Originally Posted by $tonecold
I don't see where it says anything about deflection. The instructions just say to measure from the bottom of the shoe to where the springs are sitting on the guide plate. The spring should be compressed to 1/2" or less. There won't be any deflection in the chain, it will be tight.
Thanks Stone, sounds like its a breeze to install, just dont want to overlook anything obvious only to have to drain everything out because of something not right. I appreciate posting the instructions, I only have half a page to look at ( dont have the kit yet).
Thanks everybody for the responses!
Old 04-04-2013 | 11:07 AM
Pondskipper's Avatar
Pondskipper
It is an easy install, will be pulling my primary cover in 8000 miles so will see how it looks after 20k of use, probably end of May.
Old 04-04-2013 | 11:10 AM
$tonecold's Avatar
$tonecold
Phat has it for $111.95, over $100 free shipping. Didn't see it on Direct Cycle Parts. There may be better deals, I'm just not aware of them.
Old 04-04-2013 | 11:16 AM
Bagger Jim's Avatar
Bagger Jim
Just a stupid question... I believe mine (13 street glide) has an automatic tensioner. Is there any advantage to the M6 system over the stock HD system?
Old 04-04-2013 | 11:30 AM
robvg's Avatar
robvg
TUCCI....Might as well check the torque on your compensator nut while you have the primary cover off. Mine was a tad loose. "LowcountryJoe" suggested removing it, applying new loctite and retorquing. Old loctite won't reseal according to the manufacturer. (I checked with them) Some people replace the nut due to 'stretching' of threads because of the high torque values....140 lb/ft on my model....
Good luck with the installation....It's a snap
Old 04-04-2013 | 11:46 AM
Jinks's Avatar
Jinks
The Harley tensioner will automatically tighten, but won't loosen. That "may" cause an over tight condition, it did in mine & cost me an inner primary bearing. The Hayden solves that issue.
For the OP, just slide the Hayden under the chain from the rear & push up to get the bolts in place. Use care when starting the bolts since the chain pressure will tend to make them want to cross thread. Once you have 'em well started by hand use a wrench to "snug" 'em. Keep in mind the cross thread issue & stop if you feel any resistance. Once it's "snug" measure from the bottom of the shoe to the plate the springs are resting on. You want 1/2 inch or less. If you have more you need shims, if you have less there's not much you can do about it except let the chain stretch over the next few thousand miles. Only becomes a problem if you don't have time to ride those miles.........
Old 04-04-2013 | 01:16 PM
shaker's Avatar
shaker
I just installed mine a week ago. I used a pair of channel locks with a small piece of cloth taped to the ends of the pliers and squeezed it together and pushed it in place. Didn't scar it at all and worked great. I have 26,000 miles on my bike and didn't need to use the spacers. The bike is quieter than before. I replaced the tensioner the same time I installed the SE Compensator.
Old 04-04-2013 | 01:38 PM
Sailrider 1's Avatar
Sailrider 1
Originally Posted by robvg
Installed my M6 a few weeks ago and didn't need to compress or zip-tie anything. I just slid it under the chain from the clutch side. (Had to wiggle it a bit) I ended up with 1/4" clearance and not the 3/8" per: instructions. Others have noticed the same thing with no apparent problems 'bottoming out' etc.
The measurement is taken from the bottom of the shoe to the top of the metal body or to the top of the shim if you're using one
Same with my install.
Old 04-04-2013 | 01:41 PM
Sailrider 1
amazon.com, its always the first place I search for anything. I got mine a few months ago for $94.00 and free shipping.
Old 04-04-2013 | 01:51 PM
Nute's Avatar
Nute
Quick Reply: Installing the Hayden M6 tensioner
