Road Tech Zumo 665 question
if you go the route that jmbear328 has gone with the HD zumo 665 and NIM module then yes everything will work with the NIM through your system
If you have a headset or radio that has Bluetooth and supports A2DP Bluetooth protocol then yes you can stream XM, SD Card, and GPS turn by turn directions through that device. The trick is getting it connected to do so but once connected it's great.
