Primary side cover plate tourque specs? is it needed
Location: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
Changed the primary fluid on my Limited yesterday and had the right tools except for the tourque wrench, I tighted them up but not to tight and used lock tight, am I french toast with out a tourque wrench. I will go buy one today and tourque them corectly if I need to. Please help leaving for a road trip in Tuesday morning.
I have had the primary cover off a few times, most recently as yesterday. I do not use locktite on those screw/bolts and always torque to specs. Too many other riders on this forum have over torqued their derby cover and primary cover screws and stripped them. So far on two bikes, I have not had any come loose or cause leaks.
I've had my derby cover off a couple times already since I've had this bike. Just recently to change the oil. The bolts originally had that yellow loctite that the MOCO puts on. Cleaned that out the first time I had the cover off and installed the bolts with never seize. Haven't used a torque wrench yet on them. I tighten them wrist tight. You can feel the gasket flattening as you go around tightening a little each time. When my torx starts to feel like it's going to slip out of the head I figure that's tight enough. No leaks.
This. I actually "lubricate" the threads with a tiny dab of anti-seize so the little buggers don't weld themselves to the aluminum housing, and torque them to 75 inch pounds.
EdGlide
03-08-2008 06:41 PM
