Rain sock or not ?
not wrong. your experience is odd, and what is 'plenty?' i have literally hundreds of soaked filter complaints every year at the shop
Over 20 years riding with an uncovered K&N filter on several different bikes with zero issues ever. My bikes have been ridden in every type of weather from drizzle to downpours where an ark would have been the proper mode of transport.
Also that sock restricts air flow to near stock numbers....isn't the reason for replacing the stock A/C better flow?
Again no sock - no issues, not ever.
Most of my long rides have been 650-800 miles a day. On two of those trips I encountered constant rain the entire ride home. The first trip I had an open element K&N filter. The bike began sputtering after a while and made me pull over. Not a good feeling when you are a couple hundred miles from home. The second trip that happened I had already put a cover over the filter and guess what no sputtering, ran like a champ. I would have to say that the covers work and would recommend them to anyone running an open filter on long trips!
Been caught in a few holy crap rain storms riding around the country. On one of em, riding from tenn to NC, didn't have the sock. Filter got saturated, bike started running like hell, shooting water out the pipes. That can't be good for a motor. And anyway, this is the same sort of argument as disconnecting the batter to work on your bike. Why argue against it? It takes no time or money, and it certainly doesn't hurt a damn thing.
Engines are "AIR" pumps, not "WATER" pumps. LOL
I'm not taking any chances.
I keep the rain sock on my bike all the time. Water injested into a engine is bad, it can damage the engine. If the filter were to load up with water and the engine pull in enough water at one time it could easily warp a valve or worse. This is unlikely, but with my luck, it would happen to me.
Don't agree with ones that say the sock is hurting performance either. I have autotune on my bike and have purposely run the bike with, and without the sock to see if the tune would change. NO change to the tune, even at wide open throttle, the sock didn't change the tune at all.
My sock is staying put.
If they are using paper filters then I'd understand, to a certain degree, but thats just stupid.
