Changed transmission oil and guess what happened
What weight is the gear oil you switched to? Is it Amsoil Severe Gear 75w90? Ive run that in both my bikes for a while now with no problem. In my experience, usually neutral woes come from the primary. Ive run up to 140w gear oil in a transmission without causing problems for neutral. Overfilled primary, underfilled primary, incorrect primary tension, heavy fluid in primary all cause problems finding neutral. Just out of curiosity what fluid are you running in the primary?
Amzoil 75-140 didn't Help in making neutral easier to get, nor did Mobil 1 75-140, Royal Purple 75-140 or any 20W-50. Best results were with Spectro 6 speed and Redline Heavy Shockproof. Stayed with Redline as it is easier to get where I live.
Now on my first load of Motul 10W-60 in the primary. So far so good in the first 1200 miles.
I would double check your primary fluid level and tension also if you just changed all three holes. We're all human afterall, you may have filled it a little on the high side. That would cause the symptoms you're experiencing. I know you want to suspect the trans fluid since you just changed weights, but the primary is always my first place to look if neutral is tough. If you don't find anything in the primary, I would run it until next fluid change and switch back.
Just my $.02
Just my $.02
Just my $.02
Just my $.02
muleman
11
08-10-2008 08:17 AM
