Notices
Y-Pipe
Old 03-28-2013, 12:23 PM
mrmud4x4's Avatar
mrmud4x4
mrmud4x4 is offline
Default Y-Pipe
From broken to true duals................Anybody run the true dual setup Without the rear exhaust L-Tab bracket? I see the need for the Y-pipe setup.
Attached Thumbnails Y-Pipe-28mar2013-2-715-copy.jpg   Y-Pipe-28mar2013-2-718-copy.jpg
Old 03-28-2013, 12:26 PM
kyote's Avatar
kyote
kyote is offline
I'm using it on mine...
Only issue I had was my shield doesn't wanna fit
Old 03-28-2013, 01:02 PM
mrfuji's Avatar
mrfuji
mrfuji is offline
Default y-pipe
look like my fulsac set-up on my08. love it.mrfuji
Old 03-28-2013, 03:54 PM
TSAVO's Avatar
TSAVO
TSAVO is offline
Same thing just happened to mine too. Waiting on my Dresser Duals to get here any day now.
Old 03-28-2013, 05:07 PM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
went with fulsac on mine , love them , went with a longer 1 piece heat shield on the right side , did not like the looks of turning them over
Old 03-28-2013, 06:42 PM
slimvela's Avatar
slimvela
slimvela is offline
Where did you source the shield from?
Old 03-28-2013, 07:09 PM
mrmud4x4's Avatar
mrmud4x4
mrmud4x4 is offline
Got my setup from B&E superflowmufflers. Cheaper than Fullsac.
The Extended shield can be purchased from HarleyGoodies. You have to email them..it's 60 bucks and 24 inches long. Mine should be here tomorrow or saturday.
Old 03-28-2013, 07:41 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
If mine ever cracks at the 'Y' I'm thinking of sealing the 'Y' with a cap weld and see what a home made 2-1 does for performance and sound. Can't be much different than anything you buy aftermarket....If it doesn't make it run squirly whose going to know unless you crawl under it.
Old 03-28-2013, 07:42 PM
mrmud4x4's Avatar
mrmud4x4
mrmud4x4 is offline
For the shield by my L-tab bracket, I used one clamp and made sure it was tight;the clamp on the left side. The right side clamp was right at the u-bend in the new pipe.
Old 03-28-2013, 07:58 PM
1st 96 ultra
Yea they do not show them on there web sight , you have to call or email them and they seem to sell as fast as they get them ' I had to wait a few days but not long
Rubber side up.....
Exhaust System Topics
03-29-2022 10:01 PM
icepick
04-01-2018 08:01 AM
shore
04-27-2013 05:21 PM
05Fatty
11-23-2008 10:23 AM
hangnman
08-13-2006 12:44 PM
Quick Reply: Y-Pipe
