Need Tips On Mounting Fairing Mount Mirrors
Going to put some fairing mount mirrors on my Ultra. I bought some on flea bay and while they seem to be well made there was no template or instructions so I was hoping someone that has done this can give me some tips before I drill into my painted inner fairing!!! I know this might be a dumb question but need some input.
Just did mine. The template cannot be purchased by itself. I went to the local dealer and got a Xerox copy of the template from a service tech, it worked well enough. I still have it if you want it. Btw, I raised the mounting points 3/4", and I don't look at my knuckles when I check the mirrors.
Definitely watch over tightening,as that plastic carriage bolt/screw will easily snap off. I used the template and yes it was too low of a mounting location for me also. Lucky for me I put some 14" MBB on there and now the mirrors are perfect. For the record I did snap one of my bolts off. I then took a rasp and ground off the whole bolt and down into the plastic housing enough to epoxy a new metal stud in there. It actually worked well and I was able to torque that thing down with no fear.
Radams
10-25-2013 07:52 PM
