Magnum Cable Casing Failure
I've got the black clutch cable. The cabling bunches up where it goes into the fairing and the coating is discolored where it runs down under the engine.
this isn't the cables fault but inside the fairing it has rubbed against the radio bracket I have my RF amp installed on and it is right down to the braided wire. I put shrink wrap and a piece of heater hose on it to stop it from getting worse.
I will likely switch it out to a stock HD one later this year.
Got Magnums on my King and the clutch cable came with a piece of heat shrink installed...just had to move it to where the cable makes contact and heat it up
