Think I screwed myself on my new wheel
I'm rebuilding an 06 electra glide. I picked up a newer 18" street glide wheel to put on it off of ebay. New wheel still had the bearings and sleeve installed and i was easily able to knock them out with a flat head screw driver and hammer.
I was really trying to avoid buying a bearing remover/installer so I bought a piece of threaded rod some washers and nuts to press the new bearings and sleeve in. Well I tried to doing both bearings at the same time and the tourque was too much for the 5/16" threaded rod and it broke with the bearings halfway in. I thought no big deal I'll just finish knocking them in with a hammer and block of wood.
Not thinking of what the spacer would do i finished knocking them in and realized the spacer fell inside the hub and is now wedged between the inside of the hub and the bearing at an angle so that the edge of the sleeve is up against the opening of the bearing pretty much blocking it off.
I bought the pit posse hd bearing remover/installer and was able to get one bearing out but with the way the sleeve is stuck the bearing puller won't go in far enough to catch the inside of the bearing and there isn't enough room to catch anything with the screwdriver to knock it out from the other side. Not sure what i'm going to do now.
Anyone have any ideas?
You could freeze the bearing to see if it might shrink enough to get it out easier. I think you do that with liquid nitrogen or something like that
I can only assume that regardless of what you do the bearing you eventually get out will have to be replaced due to potential damage getting it out.
I have the pit posse. It really makes no sense what you are saying. That remover lip should easily catch on the inside of the bearing bore even with the internal spacer pressing against it. Make sure you are using the correct size remover collet.
Reading this story is exactly why you cannot trust bearings in wheels you buy from anyone you don't know. Bearing races can be easily damaged by beating and bamming with wood or other shortcut blunt objects. You NEVER install both bearings at the same time. The bearing installation procedure combined with the wheel installation procedure is key to ensuring that your rotors center in the caliper(s).
If you don't know the proper procedure, you should ask or get a service manual. In the end, the correct manual and tools always, always pay for themselves. Lecture over.
Try searching for wheel bearing threads on this forum. There are several.
You guys are right I should of bit the bullet and bought the proper tool from the get go. Thought I could get it done on the cheap but guess I was wrong. I like the idea of the dremel. Been looking for a good enough excuse to buy one too.
As far as getting new bearings already a step ahead of you on that one and have a new set ready to go in.
And for what its worth the Pit Posse HD bearing remove/installer worked just as it is suppose to and I would highly recommend it. Got it for $90 off amazon and it comes with the necessary pieces for 3/4", 1", and 25mm bearings.
