exhaust stud
This is the first thread that I have ever seen about one coming out acidentally. As you said, it is usually that it snapped and will not come out at all. I am sure that the answer is in the shop manual, mine is in the garage and at 14 degrees, I am not going out there to check.
First thing I would do is buy a new stud. Why put that one back in when it has obvious corrosion at the nut end? Buy new nuts while you are at it. All those fasteners get heat stressed and replacements are much cheaper than a faupax.
Just glad it didn't break-off. That's what usually happens. Always best to spray the studs, the night before, with some type of penetrating fluid such as Liquid Wrench and let it work to soften the potentially seized parts. Works like a champ.
