Front disc mounting bolts? Please help!!
Hello all,
I am in the process of taking my front and rear wheels off so I can take them to have new tires put on. Got the rear off no problem but...the manual says you have to remove the front brake disc mounting bolts, both sides, and for the life of me, I do not know what wrench is going to take them off! 10 mm 12 point fits but since when does a Harley have metrics? Are these bolts some type of torx I'm not familiar with? Any help would be greatly appreciated. The manual does not tell you what size wrench to use except that it does mention...if you have to take apart the calipers, you have to use a Torx-40. Thanks.
This is on a 2001 Roadking.
radudel
07-02-2012 01:43 PM
