help:installed amp and now red key, no tach, and no check engine light
Old 03-24-2013 | 08:16 PM
glidin's Avatar
glidin
5th Gear
Default help:installed amp and now red key, no tach, and no check engine light
I just installed a Rockford amp in my 07 SG and that is all great but now after all back together I have red key light on all the time, tach not working, and check engine light does not come on when first pushing run switch. I hear fuel pump spraying and bike runs fine and all other things seem to be working. I checked and rechecked to make sure nothing pinched or unhooked. The dtc code its giving me is missing serial data and gives part number for speedometer. I haven't ridden to actually see if speedo is working. Any ideas as to what might be the problem?
Old 03-24-2013 | 09:43 PM
Bugsy's Avatar
Bugsy
Was the amp plug n play or did u have to tap into and / or splice into the factory wiring? If so perhaps you tapped into a computer data wire instead of a power or accessory wire? Some of the wire / tracer colors can be hard to differentiate from one another...
Also check your battery voltage. Is it fully charged? I've heard stories of strange happenings when the battery is discharged or at a partial charge state.
Old 03-24-2013 | 11:17 PM
RPS1981's Avatar
RPS1981
I know this may seem obvious, but are you sure nothing was accidentally unplugged or disturbed during the install? (i.e., tach accidentally unplugged?)
Let us know what you find out.
Old 03-25-2013 | 02:47 PM
BIGVTWIN's Avatar
BIGVTWIN
The computer on these bikes sense all kinds of things like voltage drops,open circuits,etc.
Where did you tap into for power?
Old 03-26-2013 | 11:57 AM
glidin's Avatar
glidin
5th Gear
I ran 10ga back to battery and grounded just in front of the battery where the battery grounds.
Old 03-26-2013 | 12:09 PM
dirtdobber's Avatar
dirtdobber
First I would disconnect the power to the amp, unhook it from the battery.
Just to see if it all starts working again.
Then go from there.
Old 09-21-2014 | 10:54 AM
CABAGGER's Avatar
CABAGGER
Stage I
I have experienced the same issues you talk about. What were you able to identify as the source of the issue?
Old 09-21-2014 | 12:06 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You have disturbed the tach connections. Better double check those connections first. That amp sits very close and you have moved around a lot of cables to get it in there. Probably something simple.
metaldoctor21
02-17-2016 03:26 PM
vbx07
09-17-2011 08:01 AM
cpiad
06-08-2011 12:43 AM
HDF Tech
Electrical/Lighting/Alarm
06-14-2009 08:30 AM
marinepilot81
05-29-2009 01:02 AM
Quick Reply: help:installed amp and now red key, no tach, and no check engine light
