Problem with my oil gauge.
Old 03-20-2013 | 07:39 PM
harley homeland wis's Avatar
harley homeland wis
Stage II
Default Problem with my oil gauge.
New to this forum. Thanks for having me. I'll start from the top.
I have 2001 FLHTC (80000mi). I pulled the inner fairing apart to replace the radio, replace the support brackets, paint the inner fairing. I also did some work on the primary drive, new stator, regulator, seals , some bearings clutch pack, belt. And replaced the oil lines for the oil cooler.
After I got it all back together ever thing works but the oil gauge. It's not a light but a gauge mounted in the fairing. I replaced the switch mounted in front of the motor by the rear master cylinder. And I have also replaced the gauge, both brand new. I removed the switch and tested for oil pressure and I have good oil pessure. I tested the wire with a ohm meter from the swicth to a connector under the right side cover. Which tested ok and the the fuse is ok. The light comes on but the needle does not move.
On the back of the gauge , the plug that plugs into the gauge there is a black wire and a orange wire. on the orange wire I get 12 volts and on the black wire I get 7.5 ohms when the bike is running.
Is there a way I can test the gauge it self.
This one has really got me stumped
Could use some help.
Thanks
Old 03-21-2013 | 01:12 AM
$tonecold's Avatar
$tonecold
Thanks
Welcome to the forum. So if you replaced the gauge and everything checks out, just hook the old gauge up and see if it registers oil pressure. If that doesn't work re-install the old sending unit. You don't have to install them in the fairing, just hook it up. If it registers then you have a bad replacement. I can't imagine this being the case, but anything is possible. Why did you replace the gauge in the first place and why did you go back with the stock gauge? I would have put a gauge that was easier read in its place.
Old 03-21-2013 | 01:24 AM
Harleypingman's Avatar
Harleypingman
WAG--perhaps you used the voltmeter connector on the oil gauge and vice versa.
If you have the service manual you can check the wire colors.
Carl
Old 03-21-2013 | 07:32 AM
kyote's Avatar
kyote
Harleypingman nailed it.. You have the wrong connector on it....you have the Volt gauge connector on the Oil Press gauge.
There should be 3 wires going to the oil gauge. look for a 3 wire connector with a green wire.. that's the oil pressure connector.. the green wire is from the sending unit.
Old 03-21-2013 | 07:46 AM
$tonecold's Avatar
$tonecold
The light comes on but the needle does not move. On the back of the
There should be two connectors that go to this if it still has the original wiring. There is a two blade connector that has an orange and a black wire for the gauge lamp plus a three blade connector that has an orange, black, and on my '09 bn/gn wire. Now on an '01 it might not be brown with a green stripe, but it could be. Since you've got lights that would tell me you've connected that connector, but you need to connect the three blade also.
Old 03-21-2013 | 07:55 AM
d-streetglidr's Avatar
d-streetglidr
From: South Carolina-First to secede and hopefully the next.
On my 06 the black and orange wires are for the light. Like the others said there should be a three wire plug from the sending unit.
Old 03-21-2013 | 06:32 PM
harley homeland wis
Stage II
Default Problem solved
That's it. I had the volt meter and the oil pressure gauge wires crossed.
Feeling a little humble right know. Thanks for the help, it was a quick fix.
Old 03-21-2013 | 09:33 PM
Harleypingman
Glad it's fixed.
FWIW, most of the help threads would' t appear if the owner had the HD service manual. In your case, you could look at the comprehensive wiring diagrams and learned that the oil gauge uses three wires and found your mistake.
Carl
jmorganroadglide
03-31-2012 07:33 PM
riley drake
03-11-2011 06:06 PM
Smitty0128
10-03-2007 09:47 PM
NCCopBikeRider
07-15-2007 02:06 PM
Timex
04-18-2007 11:29 PM
Quick Reply: Problem with my oil gauge.
