Adjusting Aux Lamps
Old 03-19-2013, 03:00 PM
WetSider's Avatar
WetSider
WetSider is offline
Default Adjusting Aux Lamps
I've got one aux lamp that is projecting higher than the other. Service manual says I need a special "flare nut socket" or somesuch from Snap-On - which is like $45 for a one-time use. Also, I admit that I am not "clueing-in" to how the manual instructs one should go about even getting to said nut. Do I get to it from below by removing the turn signal/housing? Checking inside the aux lamp housing shows only what appears to be the top of the adjusting nut. Any help/insight from those who've done it would be very much appreciated.
Old 03-19-2013, 03:03 PM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
Get a regular 9/16 deep socket and cut a channel out of it with a Dremel or the like, for the wires.
Here is a pict of the one I cut -- it an't pretty but it works.
Old 03-19-2013, 03:10 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
what he said and yes you get to the nut from inside the turn signal mount
Old 03-19-2013, 03:20 PM
FloridaHarleyRider's Avatar
FloridaHarleyRider
FloridaHarleyRider is offline
Or - I was able to "adjust" mine by tapping with a rubber mallet with a balled up rag. Not very scientific but they will move if they are not too tight. Side to side was easy by just holding with both hands and turning.
Old 03-19-2013, 03:40 PM
WetSider's Avatar
WetSider
WetSider is offline
Thank you gentlemen. Very helpful info. Just realized I'd done a search for the "flare nut socket" on my phone awhile back. The Snap-on part is FRX181, and it's a 9/16". Even though I have a rubber mallet, it looks like I have a little dremel-ing in my future. That's a great idea taking a channel out of a spare deep socket.
Again - thanks all.
Old 03-20-2013, 08:44 PM
billnourse's Avatar
billnourse
billnourse is offline
I made one of these years ago out of a .99 pawn shop Craftsman socket. Works just like the 45.00 Snapon real thing.
Bill
Old 03-20-2013, 09:10 PM
snip0721's Avatar
snip0721
snip0721 is offline
I did the same thing, cut a cheap 9/16 deepwell socket. I adjust, and just snug the nuts, so they stay put, but can be nudged slightly when needed......steve
Old 03-20-2013, 09:45 PM
bigheadted's Avatar
bigheadted
bigheadted is offline
I am too much of a lazy bugger so I just grab hold and tweak them where I need them to point. Since most of the time they only need to move a little bit I have never had a housing dent or cave in.This method has worked for me since 1985. Yes I know I am a lazy stupid ape.
Old 03-21-2013, 04:52 AM
katobird's Avatar
katobird
katobird is offline
I cut an old socket to , and it is a PITA to adjust them and retighten..
I also kept then somewhat tight, but with a little brute force can still move them
not a good design
Old 03-21-2013, 04:56 AM
"HI"'s Avatar
"HI"
"HI" is offline
Do I have to get into the housing of the light itself? So basically remove the trim and light?
Quick Reply: Adjusting Aux Lamps
