Adjusting Aux Lamps
The parts manual shows the stacking of the following parts:
- the passing light housing comes with a long and captive hollow bolt
- a spherical swivel block sits under the housing
- then a large flat washer spreads the load over the chrome bracket
- a second spherical clamp block is used under the bracket
- then comes the mounting bracket of the turn signal
- and finally the nut
I put a touch of Molykote grease over the spherical surfaces because they were already corroded when the bike was new.
Danke schön.
One thing Harley ought to do, and I want to try to do do myself, is put the passing lamps and headlamp on different circuits.
Received 2,530 Likes
