ape hanger cable & line question(s)
I'm figuring I'm probably going to be mounting a set of apes on my 04 RK. Probably mini-apes, but I'm not sure yet. That brings me to my questions.
1. Can I simply go a little too long on the cables on these bikes, in case I decide to go with a higher set of apes in the future? I do not want to be spending the money on multiple sets of cables and brake hoses if I don't need to. I can't see any problem with this, except for having cable sorta bulging around the tripple-tree, but sometimes there are problem I don't anticipate properly.
2. Wire extensions. Does anyone make a simple plug in extension set? Seems like everyone makes a diy splice sort of a kit, but I don't see anything like a simple and complete 12" plug in kit for the handlebar switches.
3. Are there any names to look for in the world of cable and hose kits, as well names to avoid? I see the LA Chopper kits, with a good variety of price range. I also see the Magnum Shielding page with interesting diy cables and hoses. That seems nice.
I just put 12.5 minis on my 2011 RKC. I used 6" over for both clutch and brakes. I wanted minimal cable "bow" as I use a windshield and did not want it rubbing. 6" is the minimum for 12.5 minis. Adding 2" should not hurt a thing. I actually think you can go as long as you want, it just depends on how much "bow" you want over the bars. As far as wires... I used 8" over and had just enough. I will have to rewire to go higher. Use 12" extensions and solder them. There is plenty of room in the headlight nacelle to "store" the extra wire even if you return to stock someday.
Before my mod, everything I read said buy apes 2" higher than you think you need because everyone wishes they had gone higher. I bumped myself from 10 to 12.5 and now I wish I had 14s!
BTW...I used Magnum Shielding cables and lines and they are great. The Namz wires are good as well but don't rely on the plugs....solder them.
Are you wanting to do internal wiring on your RK? I would recommend it. I am in the process of putting a set of 12" mini apes on an 03 Night Train and although the soldering and running them through the bars is a bit of a pain, it is definitely worth it in the long run. It looks much cleaner and you will thank yourself for doing it. Just my .02...
I'm figuring on internal wiring, as that's what it has now. External cables and brake hose, but electrical wires through the bars. If I've got to splice wires, I"ll solder. Wasn't sure if there was a plug in extension or not. $50 for a few bits of wire is paintfull, but they do color coordinate. The cheapskate in me looks at my generic spools of wire and thinks I should just use them instead.
I think I'll ultimately end up getting whatever bars feel right in my hands. I'm gun shy of mail ordering them, and then finding the angles just don't feel right.
