Mini Beast 5 air horn installation
I'm having some difficulty getting a Mini Beast 5 air horn that I bought on the forum about 4 months ago. I can't find installation instructions anywhere in the web.
I pretty sure the horn functions properly and the error is my instal. From what I've read it doesn't seem to matter which wire on the bike's stock wiring harness connects to which terminal wire on the horn. When I connect the positive battery terminal the horn does not make any sound other than a low moaning sound.
I've got to be missing something simple, but I'm wondering if there could be some diagnostics I could check on the horn/relay. I've seen the YouTube videos showing how to do the installation, but I'm still having no luck on this. I'm not particulary electronically inclined, but this is kind of stumping me...any advise would be helpful.
If the Mini Beast is still a air horn based horn swap the wires.
The rotation of DC motors is based on polarity, hook it up one way and it will run clockwise. Swap the wires and it will run counter clockwise. So if it is hooked backwards it will be sucking not blowing.
I also noticed from their website that they say they do not use a relay! This must be a change because I am certain that my Mini beast used a relay.
If you bought this horn second hand it may be a older style that requires a relay.
Try hooking it directly to a battery and see if it works, remembering what I said earlier about polarity.
It will matter what wire is hooked where.
They really weren't kidding!! I got it hooked up and hit the horn...my wife came running out of the house into the garage (from the basement) yelling what the hell was that?? "A safer bike" I replied. Hahahahaha.
The coil on the horn relay is to be energized by the voltage supplied by the OEM horn wires each time you press the horn button. It will be up to you to connect the relay coil to those wires.
The purpose of the relay is to handle the roughly 18 amps of current that the typical air horn draws. Your stock horn draws in the neighborhood of 3 to 4 amps, so this is why a relay is needed to handle the excessive current if you move to the air horn platform. If you didn't use a relay, you would eventually ruin the horn button switch contacts and it would have to be replaced. Those contacts are not designed for this kind of current load, even though it is intermittent. The wiring to the OEM horn is also not designed to carry this current load. So, the relay is the answer as it is in many high-current applications.
I mount my relay back in front of the battery. Use a sealed automotive 12V 30 amp relay if one didn't come in the kit. Sounds like one did, so you should be good. This will be a spst relay, designed to make and break continuity for one circuit...in this case battery voltage going directly to the horn terminal. In my installs, I choose to run the positive side of the battery through the relay, and run a line to the frame for the ground lug of the horn. For this current load, I recommend #12 stranded copper insulated wire.
Mini Beast Horn Removal
Ok, so I have a Mini Beast horn on my bike. I want to remove it and put an OEM horn on the bike so I can install a set of Ward Cooling Fans. The OEM horn has two connectors. The Mini beast has 3 wires connected to the bike. Where did the 3rd wire come from and where does it go?
same here... one year - after winter storage it died, was told to squirt WD40 before storage. couldn't get a warranty replacement. i fit in a BAD BOY horn now in same case,,, Yes - you should wire relay directly to Battery and then your stock horn wires go to other side of relay.. draw current is to high for the air horn compared to stock horn.,, yes it will work... but if u HONK for maybe 15-30 seconds non stop, i am sure u will blow a fuse...
