PoweR commander maps
OK so my 07 SG has a pc3 usb, v&H slip ons, and a screamin eagle heavy breather
Getting ready to change over to a rinehart 2 into 1. I tried to use my cd from my old bike but it doesnt seem to be working. The website just frustrated me half to death.
Any suggestions on how to get a map and download or should it be close enough to run like it is?
Power Commander Map Search URL...
http://powercommander.com/powercomma...ap_lookup.aspx
(You can select make/year/model there, and other criteria if you only want one map.)
I entered: Harley/2007/Touring and got this page:
http://powercommander.com/powercomma...dlyrid=812-511
(Scroll down to bottom, and there is a link to 'ALL MAPS' for the model I entered above.)
This is a direct link for the All Maps download (for the model I entered above):
http://www.powercommander.com/downlo...s/M812-all.exe
(You will get a download dialog. Select 'Save', then it should download to where ever you select, or your Download folder if you use FireFox. When you run the executable, it will unpack directly to your power commander folder... Usually: C/pwrcmdr. Of course, that depends on if you installed the software in the default directory)
Yea if you have the PC software on your computer, you should be able to select a map from their base. When you down load the map simply save it rather than open it. It should save it to your PC software Map file for you to easily send it to your Power commander. That combo is pretty common, you shouldn't have any problems finding a map that is very similar
albngore
01-02-2012 07:44 AM
