Dynamat in fairing
I just bought two extra large foam rubber mouse pads and used silicone adhesive to glue them to the outer fairing, directly behind the speakers. These pads are about 1/4" thick and very flexible. They contour to the curves of the fairing very well.
http://www.officedepot.com/a/product...a-Large-Mouse/
These things are big (13.3" x 13.3"), a little trimming to fit and they look like they were made for the fairing. I should have the fairing back together tonight. I am hoping for an even better sound than I have now.
I was told by a friend with many years in the audio business that this was all that I needed to do. He says that the foam rubber behind the speaker soakes up and dissipates the presssure wave from the back of the speaker. This helps prevent bass distortion, cleaning up the bass.
I actually had a couple of squares of polyfil that was used as packaging cushion. I basically trimmed these down so I could fully cover the speakers and tuck the sides into nooks/crannies of the fairing/brackets. Putting the outer fairing back on will keep everything in place...
....but I used one of those mats for in front of kitchen sink. Bought it at Costco for about $15.
First, IIRC John Scrip is an audio engineer and has a blog with useful info.
Second, I'd you go to Dynamat's website you'll see a product called Dynaxorb and am explanation of what it does. Dynamat's calls it a backwave that's created behind the speaker by the back and forth movement of the woofer cone. Dynaxorb and /or polyfil disperse the backwave so the sound from the speaker is not compromised.
You can feel the difference in the reduction of the backwave by doing a before and after test--just place your hand on the outer fairing and play some tunes. After installing Dynaxorb or polyfil, play the same tunes and you'll notice much less vibration
Carl
Apologies for the typos--pita type on the iPhone.
Carl
I did mine and it worked great. It acually pushed the sound our through the speakers much better. I was getting a rattle when I cranked it up...not any more. I would do it. It's sticky to work with though...
