Fork oil ....will it be ok?
03-07-2013, 05:58 PM
So due to a screw up I ended up with a bottle of extra heavy and a bottle of heavy fork oil. Of course I didn't realize this until I had ten ounces into one leg and six ounces in the other AND had the second bottle opened up and the last four ounces poured into the measuring cup.
Question: Should I drain and combine all twenty ounces then divide equally into forks? Or drain and combine ALL thirty two ounces and then fill fork legs?
03-07-2013, 06:10 PM
03-07-2013, 07:50 PM
i think i would drain the legs, mix, and devide between the two. extra heavy duty in my opinion is too heavy....steve
03-07-2013, 09:02 PM
you could drain them and mix the 2 equally. but that would give you a stiffer front end than the heavy and many people find the heavy too stiff.
best bet, get the viscosity that you want and do it again. right this time.
03-08-2013, 08:21 AM
I got the extra heavy by accident, I bought some 5 wt and mixed it with it.
03-08-2013, 08:45 AM
Really torqued that I made that mistake
03-08-2013, 08:53 AM
Quote:
Originally Posted by
skratch
03-08-2013, 09:45 AM
Drain it, throw it away and get yourself some 15 wt. BelRay or Maxima. Then live happily ever after.
rsking45
2014-2023 Touring Models
97
08-05-2021 01:25 PM
clarkchriston
09-17-2012 03:17 PM
HOGNOT
04-26-2011 03:26 PM
Budds
10-09-2008 07:37 PM
mr-moen
09-25-2008 09:32 PM
