Help Installing SG Tri-Bar Light and Fascia On 2010 Road King.
I want to add the Street Glide rear fascia and tri-bar light to my black 2010 Road King. I have searched and searched and think I have the correct parts to order.
Would someone that knows please help me out and verify that I have the correct part numbers to order.
If I understand correctly there will be a socket connection behind the taillamp to plug the tri-bar light if I use the 68074-07 lamp. Please correct me if I am wrong.
The parts list as I have it:
1 - 59739-09DH Fascia - Vivid Black
1 - 68358-07A Tri-Bar Light Assy. (Has longer wiring to attach to Tour Pak connector.)
2 - 59818-09 Stud Plates
6 - 7499 Nuts For Stud Plates
2 - 59749-06 Plugs For Holes In Fascia
2 - 2995 Screws For Tri-Bar Lamp
1 - Rivco Trailer Wiring Adapter - http://www.rivcoproducts.com/product...cat=255&page=2
I have added the Rivco Trailer Adapter to the parts list, at this point I think this all the parts needed for a 2010 Road King install.
Bert
Bert
Last edited by 2004Sierra; 03-11-2013 at 10:16 PM. Reason: Changed Tri Bar Light Part Number and Added Rivco Trailer Wiring Adapter.
I understand that the 68074-07 light plugs into the circuit board behind the taillamp. Now after more research I think that this socket may be occupied by the LED tag lamp.
So, if I use the 68358-07A light where would I connect it to? I read about the tour pack harness connection. Would my 2010 Road King have this connector?
I installed the facisa on my '09 Road Glide.
I took the parts and put it out to start.
Vivid Black Fascia (59739-09DH)
Screws (2995) 2 [For Tri-Bar Light]
Stud Plate (59818-09) 2 [For fascia]
nuts (7499) 6 [Stud Plates]
Tri-Bar Light (68358-07)
(I used this light without the "A" that has the harness that
plugs in the Tour Pak light plug under the left side cover.)
I decided to use the bolts to attach the Fascia.
I took the center brace and bags off to give me lots of room.
I used Harley "Touch Up" Paint on the edge of the holes and insert the Bolt Plate.
I did the same to the other side.
With the bolt plate in place, I installed the Light in the Fascia.
Note the longer wire harness on the light. The longer wires are on the part 68358-07.
If you order the part 68358-07A (with the "A") you will get a short harness.
Now the Fascia is installed. I just need to put the center brace in place.
Here is the facia in the daylight.
Here is the Fascia with just the running lights.
Here is the Brake lights.
Total time was about 2 hours. And boy, what a difference.
And I love the Road King Turn Signal Bar.
And I used a Badlands Illuminator Turn/Brake/Run module.
