PCIII Slow start
Old 02-12-2007, 09:23 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
Default RE: PCIII Slow start
You have to hook up your PC to a PC (Personal Computer)....
In the PC Tools menu, Open the UTILITY and verify the current Version..... (Pretty sure that is how to do it)...
I am not in front of my Tech PC, and my memory is about as long as my schwantz, and that aint saying much......
Old 02-12-2007, 09:40 PM
ffb's Avatar
ffb
ffb is offline
well, i have a question,
most of my performance cars have fuel injection pumps with pressure regulators ,etc,which i assume is the same set up as the harley ???
and ,i wait until they stop whirring before i hit thestart button.
the reason is to give time to the fuel pump to fill up and get full fuel in the lines .
the suggestion made of pushing the start button on a harley before the light goes off ,i think, will overtax the pump, right ?,,or not ??
any experts on this topic out there
Old 02-12-2007, 11:26 PM
gabhart's Avatar
gabhart
gabhart is offline
If you have delayed starting using a PCIII:
Watch the PCIII when you are starting the bike. When you turn the ignition on the PCIII will do it's selftest (LED's flashing back and forth) along with the bikes ECM/fuel injection. When the engine light goes out the fuel system becomes pressurized and power is removed from the system ALONG WITH THE PCIII (the LED's turned off on the PCIII, yes?). When you hit the starter button power is reintroduced to the injection system, ECM AND the PCIII. Since the power was removed and then reintroduced to the PCIII the PCIII has to go thru it's self test again thus causing the delay.
That's it in a nutshell.
Old 02-12-2007, 11:39 PM
mariner227's Avatar
mariner227
mariner227 is offline
gabhart
This makes sense to me. Thanks! I installed the pcIII and noticed the slow start. I'll check this out when I get home.
Old 02-12-2007, 11:48 PM
Neil's Avatar
Neil
Neil is offline
gabhart,
Without owning a PCIII yet, your explaination makes the most sense. When I think of how the bike starts; after turning on ignition you hear the feul pump charge, then when you hit the starter the feul pumps fires up again. It makes perfect sense. Now if there was just a way to power the PCIII with a constant lead from the ignition without the delay and the problem would go away. Good job!
Neil
Old 02-12-2007, 11:53 PM
SteveO's Avatar
SteveO
SteveO is offline
Mine fires off like on first crank after I wait for the light to go off.
Steve
Old 02-13-2007, 12:24 AM
Lurch's Avatar
Lurch
Lurch is offline
I have the delay on my 07 if I wait.
Now I just hit the Start immediately after the Run--fires right up.
If there is a firmware fix for this that would be nice.
Old 02-13-2007, 12:48 AM
Boxer Harley's Avatar
Boxer Harley
Boxer Harley is offline
Same thing happened to mine after install. Two starter push to get it cranked.
Old 02-13-2007, 12:53 AM
PhilM's Avatar
PhilM
PhilM is offline
I agree with what Bob said.... In fact, let me go back & read my original post.....
Yea.... something in the MAP. Also the idea of firmware rev differences makes sense.
When I get a chance, I'll compare the MAPs & report back.
Mine works FINE, and my MAPs work fine on units that have the problem with fuelmoto MAPs.
That's all I have to say on this topic.
Old 02-13-2007, 12:54 AM
jj9150's Avatar
jj9150
jj9150 is offline
ORIGINAL: gabhart
i was wondering about that!....i noticed the same thing with the slow start with mine, and noticed that the pcIII power light would do a weird thing if i left the engine light go off. then it would start slow. tried hitting start right away (while the engine light was still on) and presto perfect start! now what i do is kinda give it a 1..2.. count then hit start. the engine light is usually good for a 3 to 4 count, so i let it prime for a couple seconds but i hit start just before the light goes out and it seems perfect. the slow start sure seems taxing on the battery and starter thats for sure!
Quick Reply: PCIII Slow start
