Led accent lights
http://www.boogey.com/product-category/cut-n-click/
I have to say I have the Magic Wizard lights from CD and they are great with remote, several options easy to install and the service was great from CD. I have 13 PODS on my bike and there is not a single pod in a place that a machanic would have to remove it to work on the bike. Did it myself, a couple of days to do it perfectly and beer to keep me going. They are high quality I would recommend.
Just finished putting Joe Florida's lights on my brand spankin' new Iron, what a friggin' hassle, not the lights fault, mine mostly, never done anything close to that b4 and I dunno 'bout other Harleys but, this one has a huge plastic casing for the wiring harness just under the frame and above the jugs, right where you want to put the lights....I ended up putting lights between the jugs, in the "V", and it did just fine on the rear fender, so, not quite perfect but not bad. Oh, also, if your motor is mostly flat black like mine, 99.3% flat black,... I really would not buy lights for this, it don't show up worth a damn, need chrome...ok, let me re-phrase that, IF you are using Blue lights,... now White might be worth it, I never thought about it until...oh well...if and when these die out one way or another, I might try the White. And, there is no soldering with J.F.'s wiring.
Just had a couple LED's go out in a 12 light strip that are made by http://swintled.com/ .
I sent the bad light to SWINT LED's , and they shipped me another FREE OF CHARGE. I had them installed in 2008. They advertise that they are the BRIGHTEST, and are plug & play with no soldering.
Located right in Sturgis too !!
Check 'em out !
Check 'em out !
How did you go about installing the front wheel LED's? Did you put them under the fender or on the inside of the fork? I appreciate any help.
Stay away from LEDGLOW! After doing a meticulous installation where I removed the fenders and tank to hide all the wires, I connected everything and tucked the excess wire behind the oil bag just like in the video. I tested everything and it was working great. I took the bike for a ride and when it got dark I was super excited to show off my new lights. I used the app to start up my pre-programmed lights and only one zone turned on. As my friends watched I changed to a different setup and the lights went out. That was it, the controller died. I removed the seat and the light on the control box was off even though the power to the bike itself was fine. I checked and replaced the fuse but that was not the problem. I gently tugged the wire harness out from behind the oil bag and discovered that 3 of the wires had lost their connectors and bare wires were making contact and shorted out the control unit! I can't understand how these wires worked themselves loose! The quality of this kit is very poor and the design of the control box is so bad that it will short out without burning out the fuse! LEDGLOW refuses to replace the $70 control box even though they agreed to replace the faulty wires.
