Street Glide Drivers Back Rest Suggestions
Hello Friends,
Please assist me with selecting the right backrest and hardware on a stock 13 seat.
Ive been combing HD's website and a little confused. I will be mail ordering this stuff so I want to get it right.
I'm looking for a matching driver backrest for the stock seat. I would like the option to adjust its fixed position (if possible)and remove it on the fly when I'm doing short rides. Pop it on for long ones.
Thanks In Advance!
Cliff - AZ
Thanks In Advance!
Cliff - AZ
I have to agree the HD website is a bit confusing on this accessory. I am looking at future purchase, so am interested to hear from others. Seems like there are two types, one that has some adjustability and the other which has the GAS spring to adjust on the fly and have been told can be adjusted to lean full forward for easier passenger mounting. What I don;t get is the styles of pad are limited to each model type and of course you must buy the mount kit for your specific model. Perhaps those with some experience might want to chime in here and clarify for us that have not been able to see this even up close. Hope someone better than myself can help out.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
I had a riders backrest on my 2001 Road Glide, kept it when I sold it. Wanted to put a riders backrest on my 2012 Street Glide, and noticed that the old backrest was a perfect match for the new Street Glide stock seat. Got the newer mounting bracket 52589-09 ($40 at HD) and the 52914-98 backrest I had fit it perfectly. It will lean forward to get on easier. I put the mount all the way back, and it fits me well. Smaller guys may want to install the mount in a middle position. Heed the instructions about backing out the adjustment screws on the backrest until they come out. Bee-ach to get back in.
Yep, just squeeze the two support rods together and pull up. They are spring loaded. To install, squeeze them together and insert, making sure the support rod ends go into a set of holes in the mounting bracket.
So I have a 2013 Street Glide with the drivers backrest. There are two different pads that will match based on the look you like. You can get the comfort stitch or the smooth. I liked the looks of the comfort stitch better. For the mount I got the manual adjusting one since I figured that once I found the correct postition I would not be moving it. It took me a couple of rides to get the mount where I wanted it and now I wouldn't ride without the backrest.
flhxs103
12-20-2013 02:06 PM
