Pros or Cons on the Harbor Freight Lift Table?
Old 03-03-2013, 08:03 AM
SSTuner's Avatar
SSTuner
SSTuner is offline
Default Pros or Cons on the Harbor Freight Lift Table?
Just wanted to hear from users of the Harbor Freight Lift Table. Want to know of any issues to date with this unit.
Here's a forum photo from member HAPBOB
https://www.hdforums.com/forum/5856844-post8.html
Thanks in advance
Old 03-03-2013, 09:28 AM
1Bushmaster's Avatar
1Bushmaster
1Bushmaster is offline
I got mine in December. I really like it and have had no problems with it. I did however, change the wheel chock on it. The one that comes with it is pure junk.
Old 03-03-2013, 09:35 AM
WB's Avatar
WB
WB is offline
I have a couple of friends that have them and they both like'em..
Old 03-03-2013, 09:36 AM
Geoff of NV's Avatar
Geoff of NV
Geoff of NV is offline
I've had one for about 10 years. The wheel chock that came with it went straight into the scrap bin but the table has served me well.
Old 03-03-2013, 09:39 AM
lgenf's Avatar
lgenf
lgenf is offline
Pros
Cheap
Makes working on the bike easy
Tie down points
Seems to last ( most people that have them report good things, even the shops that use them)
Lay down pretty flat so even if you don't have much space you can always store your bike on them
Stable
Cons
Need to immediately swap over that wheel press into a real wheel chock the ones HF has are fine to add on, drill and mount
Can't convert to air unless you are magiver
(Some bitch it's not made in USA)
Some can't handle the drive on narrowness so you may need to add some wood to the sides (I don't have that problem with my SG or the wife's Fat Boy)
For the money there's better
Old 03-03-2013, 09:48 AM
jfarrar30's Avatar
jfarrar30
jfarrar30 is offline
Love mine. It is narrow going to find some old running boards or something I can fab to throw on the sides and be easily removed. One of these days lol. If I was using it for a shop where bikes were on and off a lot I would opt for air powered as cranking it up with your foot would get old. But for the money and the average garage it's great. Mine has bled down slowly a couple times for some reason other than that no problems
Old 03-03-2013, 10:02 AM
oricko's Avatar
oricko
oricko is offline
Had mine for about 3 years. Use it all the time, just wish it could be converted to air lift.
Old 03-03-2013, 11:19 AM
kenbo800's Avatar
kenbo800
kenbo800 is offline
I use mine for my bikes, snowmobiles, and lawn mower over the last 6 years. Has always worked well. I did build a different wheel chock though. Once you have one you'll wonder why it took so long to get it because they are a real back saver!
Old 03-03-2013, 11:34 AM
bill1nat's Avatar
bill1nat
bill1nat is offline
Thanks in advance
I have the exact same set up including the wheel chock. The only downfall to this Pros or Cons on the Harbor Freight Lift Table?-photo-1.jpg
Pros or Cons on the Harbor Freight Lift Table?-photo-2.jpg is there is no way to spin the wheels freely to clean and polish them. As the one member stated they are narrow to drive on. I made 1 foot wide ramps that are exactly the same size as the table so I can have my feet down on something stable while I drive on the lift.
Old 03-03-2013, 11:57 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 10,395 Likes on 5,514 Posts
HF is code for cheap discount over stock stuff.
Most of what hey sell in JUNK.
And chances are the long you have it the more you will agree.
Quick Reply: Pros or Cons on the Harbor Freight Lift Table?
