Pros or Cons on the Harbor Freight Lift Table?
#32
I have a HandyLift which sits a touch higher and is a little wider than the HF. My Chevy S10 easily fits over it.
#34
I use the same wheel Chock set up some what in the same place, The only thing different was after drilling the deck for the chock was to put the bolts up from the bottom and add nuts to them to keep them in place then I set the chock on the bolts and added nuts to hold down the chock. Now if I want to take off the front tire I use my plate jack to lift the front then remove the 4 nuts and the chock slides out and the bolts stay in place so when its time the chock slides back in place 4 nuts and done
#35
or just spray the wheel cholk with a little soapy watter and spin the wheel while it sits in place
