O2 sensor bung install
Thanks, but....
Thanks for the reply, but I was looking for an actual dimension since I don't have the bungs yet and I can't find those dimensions anywhere on the internet.
When I did mine on my '04 EG w/ Rinehart true duals, I had the bungs, placed them on the head pipes and used a permanent mark the location to assure adequate room for the 02 sensors, then removed the head pipes for a local muffler shop to weld for me since I don't weld.
I describe what I did because there isn't a lot of room to locate the bungs w/o creating interference with the heads/cylinders when installing/removing the 02 sensors.
Carl
Carl
I describe what I did because there isn't a lot of room to locate the bungs w/o creating interference with the heads/cylinders when installing/removing the bungs.
Carl
Carl
FYI, On my '12 & '13 FLHTK's, I removed the headpipes and installed a set of V&H #16759 Power Dual head pipes for 2009 application that had the 18mm bung welded in location. 10-13 uses a 12mm bung for the samller 02 sensors and 09 had the 18mm bungs near the exhaust ports. Piping is same except for bung diameter, angle, and location.
Thanks!
Carl
Carl
BTW, Carl. I used info from a lot of your posts in putting together my sound system (i.e. accessing the rear channels, etc.) and it functions flawlessly and sounds awsome! Many props!!!
Glad to help with the bungs, and I understand the desire to do as much prep work to get ready to install accessories. (Note: in my original post above I erroneously referenced "bungs" being installed and removed; should have said 02 sensors; the error has been corrected in my post, but the quotes in subsequent posts doesn't pick-up the correction.)
As for the audio, happy to help; I had a lot of fun learning a lot of stuff I didn't know before trying to do some of these things and passing along what I'd learned just as many other members have done here on HDF.
Carl
Carl
That sounds like good advise that I intend to follow. I'm was getting a little anxious and was hoping to get some prep work before the O2 sensors even get here. But perhaps some patience is in order. I've still got cams to install anyway. Thanks again!
Absolutely right; there is very little room to locate the bungs to work with the sensors.
Another suggestion--have a chase handy to clean out the threads of the bungs for easy installation and removal of the sensors. I don't know if the muffler shop I used screwed up the bungs, or if they deform from the welding heat, but I found it impossible to install the sensors until I used a chase (actually a die?) to clean up the threads.
Carl
Carl
Bung location near the exhaust port is key for best performance and the angle they are installed is critical. The 12mm O2 sensors used for stock bikes have a narrow bandwith. The 18mm units are significantly larger and operate over a much wider bandwidth.
Take your time with the fabrication, as the angle and depth of bung in the header is everything. You don't want to get that header on with the O2s installed and have the O2s come close or contact the cylinder fins. Take your time and all should go well.
