I'm installing new bars and I bought the Screaming Eagle TBW kit to eliminate the green plug in the middle of the bars. The green plug accounts for 6 wires. There is a black and white wire which are in a 2 pin plug. It's been a few weeks since I took it apart but I'm not seeing anything to plug it into. And I can't seem to find it in the HD service manual. I do see in the svc manual it talking about a 2 pin plug internal to the right side in the handle bar for heated grips. Is that what hose two wires are for?
I used the SE TBW wiring on this last install but as for the green connector that is a bit fragile, in my last two installs I simple put a piece of shrink tubing over the connector and sealed/supported it with that, worked fine. This is for those contemplating options on this.
