clutch wiz for touring
Old 04-07-2018, 03:42 PM
F150HD's Avatar
F150HD
F150HD is offline
Received 1,289 Likes on 848 Posts
Originally Posted by jammerx
You can buy a product similar to the Muller
https://www.harley-davidson.com/stor...B&gclsrc=aw.ds
https://www.amazon.com/Clutchlite-68.../dp/B001QWUBU0
https://www.jpcycles.com/product/631...ite-clutch-kit years ago I had this in my EVO and it worked good.
It seems the ramp assembly has tripled in price!
Unless its already in your bike!
J&P part looks promising...will read up on that.
Sauls (04-13-2018)
Old 04-07-2018, 05:11 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,954 Likes on 4,032 Posts
Clutch wiz lower lever pressure by lowering the pressure plate pressure.. You are better off getting the right diaphragm spring in the first place as they are cheaper.
Old 04-09-2018, 09:20 PM
Gamma742's Avatar
Gamma742
Gamma742 is offline
I have never been able to get the diaphragm spring out without removing the outer primary cover. Some say you can do it through the derby cover ....good luck with that
Old 04-10-2018, 07:32 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Keep trying. It will come out...but you have to find the right position. Takes some fiddling. I've done it half a dozen times.
Old 04-27-2018, 08:35 PM
Jeff McKinney's Avatar
Jeff McKinney
Jeff McKinney is offline
Originally Posted by beasleyiv
I have a clutch wiz hanging on my shop wall. Let me know if you're interested in it...
If f150 isn't interested what are you asking for the clutch wiz?
Old 05-01-2018, 07:52 PM
Gamma742's Avatar
Gamma742
Gamma742 is offline
I have one of these it someone is still looking for one. PM me..
Old 05-28-2018, 04:58 PM
gwstas's Avatar
gwstas
gwstas is offline
1st Gear
I had to replace a clutch cable on my wife’s 2012 triglide with clutch wiz installed. I can’t find the instructions for adjusting the clutch but know it does adjust differently than the stock clutch. Does anyone have the adjustment instructions and could you post them here?
Thanks,
George Springer
Old 05-28-2018, 05:18 PM
Max Headflow
Thanks,
George Springer
It adjusts the same. It's pretty much simply on way of lightening the plate pressure in the clutch. None of the ramps change.
Old 06-05-2018, 04:47 PM
Snowballs Alaska's Avatar
Snowballs Alaska
Snowballs Alaska is offline
Stage III
Thumbs up ClutchWIZ for Tri-Glide
I had a ClutchWIZ installed in my 2012 Tri-Glide and I love it. I have arthritis in my hands and I appreciated the reduced effort to pull and hold the clutch lever. It is also now easier to find neutral. That's a big thing for me.
Old 06-05-2018, 04:50 PM
Gamma742's Avatar
Gamma742
Gamma742 is offline
Yep! and I still have one if someone needs/wants it PM me
32roadking
07-29-2018 02:02 PM
Casper
09-03-2015 03:11 PM
kdrperformance
Touring Parts
11-13-2014 04:00 PM
patrickd
Screamin Eagle CVO Models
10-01-2014 05:06 AM
cike
EVO
04-19-2012 01:44 AM
Quick Reply: clutch wiz for touring
