Aftermarket Fairing questions
I'm curious about aftermarket fairings, even though they don't apply to me.
For the quick release/mount fairings with audio, how long does it take to connect/disconnect? Are there visible cables/wires?
What are the disadvantages of just ordering an HD EG/SG fairing? Cost? Or the handlebars get in the way?
With the "handling advantage" of a fixed RG fairing, why aren't frame-mounted aftermarket fairings offerred, or are they?
Considering you asked about the quick release, the disadvantage of just ordering an EG/SG fairing is that they are not designed for quick release, the gauges (speedo, tach, etc...) are designed to fit into specific areas of the fairing and would require major re-routing of cables and wires to have everything work correctly, thereby negating any "quick" removal as well.
As for aftermarket frame mounted fairings, vetter (shown in an earlier post) used to make some, but again, if you're attaching things to the frame of the bike, it's generally not going to be a "quick" release.
More info on Vetter.
All of the aftermarket Batwing style fairings mount to the windshield mounts on the forks and most are quick release with a couple wire plugs to pull. The HD Factory fairings can be modified to be quick release but its easier to get a Dragonfly or Matasu, Woodys,Sportzilla, Tsukau, Reckless, etc and put it right on with out modifications and probably a lot cheaper.
To mount a RG Shark nose is a frame mount and can not be done quick release, but it can be done either with the HD Factory parts to convert or there are aftermarket companies that make the mounts but you still need the HD Fairing as I dont know of anyone that makes a replacement
The mount for the DCC I had was a slip in on the stock W/S grommets and had a trip latch to keep it on bike with a key lock, had a three wire Deutz connecter that powered the radio and accessory port, was a snap to have it off or back on in just a few moments when I washed the bike or wanted to ride open.
I really did enjoy having it on the bike.
vegasjones
10-16-2011 07:18 AM
