Installed Auxillary Brake Light Kit (pics)
Old 02-09-2007, 08:30 PM
Pastor John's Avatar
Pastor John
Pastor John is offline
Default Installed Auxillary Brake Light Kit (pics)
Here's a quick and easy installation that improves the visibility of our rigs and probably improves safety. The Auxillary Brake Light Conversion Kit (#69461-06A) runs about $55.
The kit comes with two new red lens covers, a wire harness, and some zip ties to secure the wiring. You will use your existing bulbs. Here's the harness adapter that is included in the kit.
Start by removing the seat. The connector for the existing rear lights is on the fender and easy to get to.
Simply disconnect the existing harness and add the new harness into it. There's only one way that it will go, so even I couldn't mess it up! I tucked the completed harness between the fender and the frame.
Put the seat back on, making sure that you have placed the new harness out of the way so that it can't be pinched. Replace the existing amber lens covers with the new red ones and you're done! About 15 minutes and a lot more light for motorists to see!
Old 02-10-2007, 09:56 AM
BirchwhiteHD's Avatar
BirchwhiteHD
BirchwhiteHD is offline
Default RE: Installed Auxillary Brake Light Kit (pics)
I have one of these on my bike,it does work well to add alot more light to the back of the bike
Old 02-10-2007, 10:02 AM
Abnmarine's Avatar
Abnmarine
Abnmarine is offline
Nice install and write up John.
Old 02-10-2007, 10:05 AM
electaRICK's Avatar
electaRICK
electaRICK is offline
yea,, thanks for that,,,,, I like them mods,, cheap ,EZ, and mostly practical!!
Old 02-10-2007, 04:52 PM
Lawdawg's Avatar
Lawdawg
Lawdawg is offline
I have them on mine, I like them. Now to find the light thingy that makes them flash with the brakes on.
Old 02-10-2007, 05:03 PM
soos's Avatar
soos
soos is offline
ORIGINAL: Lawdawg
I installed this unit #IBF4from Comagination for directional/brakelight/flashing. It works great. http://www.comagination.com/bflasher.htm
Old 02-10-2007, 05:12 PM
RANDIT's Avatar
RANDIT
RANDIT is offline
nice write up
Old 02-10-2007, 05:44 PM
vtxed's Avatar
vtxed
vtxed is offline
Do they have it for the street Glide
Steve
Old 02-10-2007, 05:57 PM
soos's Avatar
soos
soos is offline
If you are asking about the HD module, the answer is yes. What you need to look for is the unit that has your specific replacement lenses. Look in other sections of the HD accessories catalogue for this unit. The module is the same.
Old 02-10-2007, 06:21 PM
CTClassic's Avatar
CTClassic
CTClassic is offline
Since I've installed this on my Classic last year, they came outwith a harness which does the same thing, PLUS has the running lights as well, $60 I think.
Quick Reply: Installed Auxillary Brake Light Kit (pics)
