Help with changing out Front Signal Brackets 2012 Street Glide
Day off today so I thought I would start some long out put off winter mods. I bought some black powder coated front turn signal brackets and I just started to pull them off and I can't figure out an easy way to remove the turn signal wiring from the old bracket. Once you unclip the wire from underneath the fairing the plug end is too big to pass through the hole and I can't see how to disconnect the wire from the actual blinker. I hope I don't have to cut the wires just to do this. Any help would be greatly appreciated.
Sorry Fat Daddy I appreciate the help but you don't quite get where I am at. I have the actual turn signal and bracket in my hand, so I have removed the fairing, and now I want to pass the turn signal wire through the hole in the bracket so I can pass it through the new bracket. Wolfman 66's idea was great but I cannot seem to be able to push the pins out of the housing. Must be a trick.
DeadBirdDog
2014-2023 Touring Models
13
07-02-2015 04:30 PM
June Bug
03-08-2009 03:06 PM
