Quick Detach Backrest ?
I have installed a Quick Detach Tour Pack kit (53303-07) complete with the deutsch connectors. My question is what docking hardware do I need to install for a quick detach passenger backrest. It looks the tour pack docking would double for a quick detach luggage rack. It also looks like if I added docking hard ware for passenger backrest the tour pack docking hardware would interfear with the passenger docking hardware an mounting of the backrest. Thanks in advance. A closeup pic of this setup on a scoot would be great.
There are four docking points; two for the tour pak and two different ones for the passenger back rest(sissy bar). You can't have both on at the same time. It gives the bike two different looks. I can down load a couple of pics when I get home if someone has not already posted the two different views.
No.
The docking hardware in the picture you posted is for the detachable Tour-Pak and/or detachable luggage rack.
The detachable sissy bar upright/backrest requires the addition of a second set of docking hardware closer to the seat. Look at the photo below. It clearly shows the hardware you have (indicated by the number 2) and the hardware you need (indicated by the number 1).
Part number is 53803-06 is for the detachable backrest and it's on page 342 in the 2013 Parts & Accessories Catalog.
I have all three -- detachable Tour-Pak, detachable luggage rack, and detachable backrest. So I'm somewhat familiar with this setup having installed all four docking points (i.e., both sets of hardware) on my bike.
Bear in mind this is for pre-2009 bikes. 2009 and later use the upper shock absorber bolt as a docking point. It's a whole different docking system.
