radio fuse keeps blowing,any help where to look ?
the bike is a 2007 electraglide classic. The radio fuse keeps blowing,sometimes it will hold for a little while but mostly blows rite away after starting bike, i have changed out the speakers a couple years ago, i looked around under the fairing a few time and cant find anything looking like a short.
Could it be inside the radio? any one have the radio go bad and blow the fuse ?
i want to put the J&M amp and lower speakers but i got to fix this first. Thank`s Will
look for insulation rubbed through on a power wire to the radio.
IF the fuse is black inside like something exploded- that indicates a short circuit
if the fuse material looks like it just sagged and parted, that indicates an circuit overload- like might happen if someone used the radio circuit to run extra lights, for example
mike
mike
lots of good suggestions men, thank you . i do wash it alot,and rode in the rain many times, i had the fairing off looking around, i cand fine anything,
i will check the batterie cables, i did change the battery recently mabe loose,
Any more thoughts? i would love to fix it! thinking of apes too!
lots of good suggestions men, thank you . i do wash it alot,and rode in the rain many times, i had the fairing off looking around, i cant fined anything,
i will check the battery cables, i did change the battery recently maybe loose,
