Anyone running 19" Agitator with stock 16" rear?
well, in reality, the rake is pretty much preserved. the lower profile of the 18 only slightly raises the rear end of the bike. i think it works out to about 3/8''. don't think that is going to make much difference in the big scheme of things.
16 - 19 on a FLTRX
Mines in the shop now getting a 16" Smoothie rear and a 19" agitator up front. I have a 1" lowering block in the back and I'm installing a set of progressive mono tubes up front and lower them 1"
I'll let you know ASAP. Should be done in a couple weeks..... its getting an Andrews 57H cam, Black Opps lifters, new sprocket and belt as well...
Ron
Ron
these are all stock dunlop tire sizes, other brands may (will) be slightly different.
front
130/90-16: 25.21 diameter
130/80-17: 25.19 dia
130/70-18: 25.17 dia
130/60-19: 25.14 dia
rear
185/65-16: 25.47 dia
180/55-18: 25.80 dia
remember to halve this difference for the radius to give you the height difference. and interesting to note, the 16'' tire is actually the tallest of them.
and the rear tire actually raises the rear by .165''. so hardly noticeable
I was going to buy my agitators and rotors online to save some money and hit my local small cycle shop for tires but ended up buying every thing at New Castle Hd. saved on shipping costs and running around and they installed the bearing kits and mounted tires and rotors for free because I bought it all there.
