Road King Seat Mod
Old 01-31-2013 | 08:46 AM
mikelikesbikes's Avatar
mikelikesbikes
Took mine off long ago and OL never noticed.
Old 01-31-2013 | 06:58 PM
kel03's Avatar
kel03
Lok Tite, yea, maybe should have explained it a bit more like you did.
The process of undoing it, even to switch to a single seat @ home takes time.
Just thought, that maybe someone had made up a quick disconnect even for detailing reason to get under the seat without pulling wrenches, realigning.
Old 01-31-2013 | 08:12 PM
Zimbob's Avatar
Zimbob
I took mine off of my '07 and chucked it on the trash pile. She liked the scoot with it but never noticed it was gone.
Old 01-31-2013 | 08:29 PM
Loc_Tite's Avatar
Loc_Tite
I got to thinking about it today and went out to the garage. Folded the strap ends under the seat, drilled 1/8" holes through the plastic in the seat where the holes in the metal strap tabs were, then ran 3/4" long lag screws through the tabs into the plastic. The lags are way short of coming through the other side and the heads are nowhere near making contact underneath anywhere when the seat is mounted. I don't recommend this approach if your passenger uses the strap to hold on, because although it feels solid it may loosen up from constant pulling, but in my case I need it for looks and to attach my gym bag to.
Old 02-01-2013 | 01:24 PM
Joe12RK's Avatar
Joe12RK
Originally Posted by Nomadmax
On a Road King Standard you're right, just unscrew the phillips and take one side of the strap out.
BUT
On a RK Classic BOTH ends of the strap are riveted to the mounting bracket on the hard bag mount. In order to take the seat off you have remove the strap bracket from the bag bracket and thread it thru the cuts in the seat before you can take the seat off.
Kinda a PITA
Can you install the chrome brackets from an FLHR on your bike?
Old 02-01-2013 | 01:35 PM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
Naw, the brackets are completely different and come in at a different angle. The RKC seat weaves the strap though the seatcover. I got mine squared away though, I replaced one side with a dowel/cotter pin. It's as secure as it was stock.
MorrisGray
09-14-2013 09:55 PM
ib5150
12-29-2012 07:52 PM
hellfrozeover
08-22-2011 03:50 PM
USMCNewdog
04-18-2011 07:03 PM
Lopoetve
11-19-2008 12:00 PM
Quick Reply: Road King Seat Mod
