103 Big Bore vs Stock 103
01-30-2013, 12:17 PM
Are there any differences between a 96 w/ stage 2 over Stock 103.
Only thing I can see is, maybe; Cam 255/259e, SE aircleaner....
01-30-2013, 12:27 PM
Thats it. A stock 2011 or newer 103 uses the same cams as the 96, a 103 Stage 1 is just cyl and pistons to increase to 103, a 103 Stage 2 is cyl , pistons and cams
01-30-2013, 01:05 PM
if installed, a "big bore kit" would do well to include compression releases as well as pistons and cylinders
Mike
01-30-2013, 08:55 PM
I believe the flatop cast pistons in the stage 2 kit have alittle more compression than stock 103? 9.6-10?
01-30-2013, 10:26 PM
Quote:
Originally Posted by
mkguitar
Mike
+1 on the releases. I swapped out my stock heads and put on some 2012 take-offs with ACR's. Big difference if you have the 103 BB.
Gearhead_573
General Topics/Tech Tips
01-30-2020 04:49 AM
jpdeville
Engine Mechanical Topics
08-06-2017 02:45 PM
bigblock59
01-06-2013 04:43 PM
cwickgo9
Exhaust System Topics
11-27-2007 06:26 AM
sugarbear
01-20-2007 12:05 AM
