Help w/ H-D garage door opener
I need some help with the install of the H-D garage door opener that works by hitting the high beams (part #91558-01A). In the instructions under "Harness Connection" for my FLHX (section 2 under Touring Models) it says, "See figure 9. Cut the yellow(6), black(4), and white(5) headlamp wires inside the fairing......." In section 3 it says, "See figure 15, the 2 into 1 splice configuration. Use a red splice connector (Figure 27, item 4) from the kit to slice the black garage door opener transmitter wire to the black wires (emphasis mine) from the headlamp........" My issue is that the black wire (item 4 in figure 9) cut in section 2 is a single wire w/ a factory connector which comes from the wire harness and not from the headlight. My question is do I connect the black wire from the transmitter to the black wire identified as (4) in figure 9? (Which would not be a 2 into 1 splice) Or is the intent to cut the black wire from the headlight and do a 2 into 1 splice as your supposed to do with the yellow and white wires from the headlight? I hope I stated my situation clear enough that someone can help me out. Thanks!
Ditch that overpriced trinket. Go to Home Depot and get a keychain garage door remote, put a little square of Velcro on the back with another tucked up under the left side of your tank or low and out of sight on your fairing. The savings will buy you a dozen tanks of high octane or a few decent meals out. Find a tiny HD sticker to put on it if that helps.
Company called MO-Door makes one that cost 60 bucks and if you dont like the button wire it to the aux. Easy and cheap. F@ck that high low beam BS haha.
dingodelgado
Electrical/Lighting/Alarm
17
10-14-2021 07:04 AM
Fatboy2
General Topics/Tech Tips
12-18-2005 08:40 AM
