Accessory switch
on my 07 it was under the seat just in front of the battery,the one in your pics doesn't look like it.it was similar with 4 lighter gauge wires into the back and a rubber plug ontop,under the rubber plug 4 small holes that accept duetch connecters.u can get a harness from dealer or use crimp on duetch connecters.the acc switch controls one hole other is acc switch.
As mentioned its a 4 plug duetch terminal under the seat with a rubber boot plugged into it you can buy the harness adapter at Harley,JP cycles,etc. $18.00 to $35 .00 I bought the duetch conn. at a local heavy equip. dealer and made up my own.One port is acc.switch pwr. one is brake lights one is running lights and the other is signals.
Last edited by South Jersey Scooter Trash; 01-27-2013 at 08:33 PM. Reason: more info added
Agreed. The wire you posted a photo of is B+. Not only is it not switched, I'm not sure it isn't still hot even when the bike is off? I may be wrong about that part. But it's not the wire you're after.
You're looking for a square plug that will have four wires going to it. It's under the seat, near the battery. It has four pins (or sockets? can't remember if it's male or female). The four pins/wires in the plug are: (1) ground (2) hot whenever the ignition is on (3) hot whenever the brake is on, and (4) the one you want, hot when the ignition is on AND the accessory switch is on.
These are all in one connector. I'm too lazy to run down to the garage to get the service manual. The wiring diagram shows which color wire is which. I've seen it posted in other threads. You'll figure it out.
...and the B connector is always hot. This is the wire you want if you buy Jason's fan kit with the thermal switch.
