Accessory Adapter Harness Kit
02-07-2007, 04:47 PM
Does any know where to get additional connectors for the H-D 70270-04 Electrical Accessory Adapter?
02-07-2007, 06:14 PM
RE: Accessory Adapter Harness Kit
I went round and round with this last year.... I'll see if I have the part numbers for the plastic piece as well as the pins.
02-07-2007, 09:14 PM
Batts Racing do the original connectors for H-D, at a fraction of the cost.
Brian.
02-07-2007, 11:36 PM
Here is what I found:
Part # 72289-04 Female pin
Part # 72105-04 Male Pin
Part # 72100-04 Terminal Housing
02-09-2007, 12:20 PM
Does Part # 72100-04 Terminal Housing include both (male & female)the small and the large housings? If not, is it just the larger one?
Thanks
02-09-2007, 12:40 PM
Just the large one... just the plastic piece.
02-10-2007, 10:08 AM
I have an extra one. Are you talking about the accessory that connects to the acc. switch on the dashboard? If so I don't know if you know this but the switch connector for that is between the battery and the gas tank and it has a rubber connector on it to keep it clean....
I only say this because I just installed a Zepplin seat and after putzing around for a bit I found the connector. They make a connector that goes into that with a "Y" so you can add 2 accessories......if you already know all of that then forgive me for going on. Your Harley dealer can order the "Y" for you or if you want to I'll sell you the extra one I have......
Good Luck
ROLLNTIGER
Audio Systems
05-15-2014 02:33 PM
The_Kid
05-13-2014 03:16 PM
vhmike73
Audio Systems
04-25-2014 01:30 PM
rpmpit
05-20-2013 01:49 PM
jarhead45
08-11-2009 02:46 PM
07 ,
7210004 ,
accesory ,
accessory ,
adapter ,
davidson ,
electrical ,
harley ,
harleys ,
harness ,
housing ,
kit ,
roadking ,
rockwall ,
terminal
