Having gutted many HD head pipes I can tell you that the front head pipe extends into the collector 4 1/4 inches from the center of the front o2 sensor bung. The rear pipe extends into the collector 3 1/4 inches. This separation of gasses keeps the sensors from cross talking regardless of cat or no cat. This is at least as much separation as any aftermarket head pipe I know of. IMO the HD headpipe works as well if not better than any aftermarket headpipe on a stock engine. When cams are changed to performance camshafts then a noticeable performance gain can be obtained by installing a aftermarket performance headpipe.
One consideration is reversion; even though the cat does not pose a significant restriction to the exhaust flow, it does create a sort of 1 way valve, when it is removed fresh air is free to get sucked back in between pulses and cause errant readings.
And that is why having Wide Band o2s at each head is such a good idea (instead of prior to the cat). As the fresh air attempts to migrate into the heads, the sensors adjust accordingly. HD is doing what it can to please the EPA.
On most cars, there are o2s at the head pipes as well as just prior to the Cat/s.
