4-way flashers
4-way flashers
i have 01 electraglide classic i changed all turn signals,brake lights and tour-pak lights to leds. took bike to shop for shifter shaft seal leaking ,flasher problem well they started working on it bike would not start bad battery (almost 4 yrs.old)got new one fixed seals,checked flasher problem found ioad equlzer bad and module that turns turn signal to brake light bad. replaced but 4-ways flash about 4 times when you turn switch on they checked no codes cannot find any reason for this to happen.i also 2 yrs. ago has tssm removed and put in just a tsm. but flasher problem just started 2 months ago. he said to ride it runs good just annoying.what do you guys think?
