Road King Reduced Reach Bars
I have a 2003 Road King Classic. I am attempting to change the stock bars to the reduced reach bars. The wiring harness is supposed to run "inside" the new bars, whereas it was routed outside on stock.
Can someone tell me how to get the friggin' wiring harness inside the bars without taking any connectors off? I can't figure this crap out to save my soul! Don't want to pay for three hours labor to the dealer! And instructions suck!!
Mcubed
Mcubed
RE: Road King Reduced Reach Bars
Well, I think you're going to have to remove the connectors in order to fish the wires through the bars. You should be able to use a nail punch or toothpick to pop the individual wires from the connector (be sure to mark which wire comes from what plug). That looked like such a pain (and the entire harness needed to be lengthened on my '07), that I let the dealer contend with it. As I stood beside him and watched for the first hour, I figured that $78/hour X 3 hours was worth not having to do it myself.
Thanks so much PJ! I was afraid of that. It states in the instruction sheet, specifically NOT to remove the wires from the connectors, but that is contrary to common sense. The connectors will not go through the bars.
I appreciate your reply. I am going to call the dealer today and ask the service folks about it. If they contend as you do, then I will most likely bite the labor and let them do it as well. Why on earth do they make things so hard?
Again, thanks for the input. Peace and ride safe!
Michael
Michael
Check this link out. Not the same bars but good directions on the rest of it. http://www.bikernet.com/roadkingrepo...Article=122002 Scroll about half way down and it shows ya how to deal with the plugs and pins. Hope this helps.
ORIGINAL: PsycleFreak
I did it and and love the end result.
Can't beat these instructions.
http://www.moccsplace.com/images/harley/hbar/hbar.htm
You can definitely do it yourself, it's really no big deal. Make a little diagram of the harness before removing the pins. It took me longer than the dealer, about 10 hours, but that included removing the nacelle, bars off then on, and switching my brake, clutch, and throttle cables to braided stainless, oh and replacing my grips and chroming the controls. While you have it apart you may want to see if there is anything else you want to take care of in that area.
I just took up close digital photos of the connectors so I knew where to put them back.
Took less time.
The hard part for me ws figuring out the routing of the throttle cables so they didn't bind and didn't rub along the tank on RH lock-to-lock.
Good luck, and just enjoy doing it yourself and bonding with your bike.
Took less time.
Hey everyone,
Great big cudo's to you all for being so helpful. All of the comments will prove to be so invaluable. I am convinced now that I know how to disassemble the connectors without mucking **** up, I am ready to proceed.
You all are great, and this is a great web site.
DrPlastic
11-10-2007 10:22 PM
