putting inner fairing back together but have this connector that we can't find the other end to. It's part of the throttle by wire assembly. It's not the green connector. ( I cut and soldered those wires) This is the black connector for that part. Does this wire go to anything or what's it for?
I agree, heated grips. You should have another female black connector with a black and white wire not hooked up as well. there are also red and black wires with same connectors. red/black goes to harness...blk/white connects grips together
