View Poll Results: A poll
Voters: 117. You may not vote on this poll
Wheels, wheels, You decide.
RE: Wheels, wheels, You decide.
ORIGINAL: onlythebest
None! Bolt right on. I kept the rear rotor and pulley factory and got the lemans rotors for the front and used HD fatboy spacers in the front. Check with hogpro about the teeth count in the pulley for the 06, I think its different that the 07 and may need to be changed for the 18inch but I kept my stock one. No handleing issues. I did notice a bit of rub on the inner front fender but just a touchafter a100MPH run to the Keys. I have the 21/3.25 and 18/3.50 or 150?? rear. hope thats right?
Swany
Swany
Can I still use my stock pulley? Sure hope so. Would I loose any braking when swapping out the floating rotors? Can I use my current brake pads? Tires will probably be Avons with a 150 out back. Anything else needed other than the FB spacers if going with a 21" front?
Hogpro suggested going with a 18X4.25 and a 150 tire for the rear. I heard metzler was a better tire than the avons. I dont have any experience with either brandbut thats what was suggested to me. I like the look of a 21" on the front. so i say 18s in the rear and 21 in the front. post some pics if you get a pair.
ORIGINAL: Abnmarine
I already have HD floating rotors with Lyndal Z pads. I would keep this on the rear since it isn't seen and use this on the front:
Swany
Swany
ORIGINAL: Abnmarine
Aren't our factory wheels a 3.5 width?
I'm not comprehending the rear pulley issue. Seems to me that I should be able to use the stock one on the new wheel. [sm=confused06.gif]
I could be misfiring! Just know we talked about putting on a new pulley but wasnt getting that your staying with stock. Disregard! Its 1208 am here in Israel and im beat!
ORIGINAL: Abnmarine
If you're buying rims get a 4.25" on the back so you can runa wider tireya know. Like several have said, Hogpro does this all day. And some have gotten a 160 on the back in this configuration although they recommend the 150.
lp
lp
ORIGINAL: Abnmarine
I agree. I'm leaning on the 18" front/rear in chrome. I guess I now just need to know if the 3.50 size is correct.
ORIGINAL: DI75
Unless you are going for the blacked out look I would go with the chrome!! What the hell do I know though!![sm=icon_quiet.gif]
